Hallo
Ich bin ein ungarischer Kerl
Meine Frage bis 90 245, 245 (C20XE) BC, welcher Wegstreckenfrequenzgeber normal arbeiten 6 oder 16 Impulse?
danke
ich bin:
https://www.facebook.com/profile.php?id=100011321839266
Hallo
danke
ich bin:
I will try answer in English language because it might be easier to translate into Hungarian language.
In principle - assuming factory Kadett GSI 16v or 1 to 1 conversion into another carbody - it does not matter what distancy frequency generator (DFG) you have installed because the BC receives its information on fuel consumption, remain tank contents etc. from the ECU or directly from the measuring gauge for its calculations. You need it only to get the right speed information in your tachometer (I assume the LCD) and average speed.
In case of the LCD you can change the DFG used from 6 to 16 by the switch at the top middle of the LCD. You can use any DFG except the ones marked with "AD" which is for automatic gearbox because you do not need the speedo shaft, only the impulses. When using the 6 impulse variant the LCD should show 125 at ignition, otherwise it should be 127 for 16 impulse.
You can find additional information on this subsection of the website ascona-info.de (in German only)
http://www.ascona-info.de/LCD-Tacho.html
This website might help also in other cases because the oldschool Opel like Kadett, Ascona etc. are similar in their simplicity and conversions like motor swaps are still well-established
Hope my response will help you?
Best regards
Alles anzeigenI will try answer in English language because it might be easier to translate into Hungarian language.
Best regards
Danke für die Antwort.
Jetzt gibt es sechs Impulse,
und die Durchschnittsgeschwindigkeiten sind nicht gut gemessen.
wenn 100km / h ich gehe, dann meine Durchschnittsgeschwindigkeit von 37,5 km / h, nach BC.
Der Unterschied Punktzahl Prozentsatz als zwischen 6 und 16!
Deshalb glaube ich, dass die 90-245 245 für den Impuls 16. ärgert
Nach Ascona info.de Seite kann nicht in fünf der 90.245.245 11,12,13 masse codiert werden
mein lcd Tacho- gutes Maß
nur bc schlecht gemessen
When the LCD tach shows the right speed it think this is sufficient.
But when you want have everything right you should look for the right DFG with the markings AK or AG.
And I found out that you might be a lucky man because there are a few available on ebay:
